Hello everyone!
Need some advice. I had the dreaded valve cover leak that eventually killed the starter. I put a new starter in and it fired up no problem. After, I went back to the power wire connected to the solenoid to make sure it was tight. Like a dummy, I forgot to disconnect the battery again and I made grounded contact with the wrench. Surely it wouldn't start after. Figured I fried the solenoid so replaced it with a new one. Put back together and still no start. My fuses and relays look good. Any suggestions were to start looking? 2002 4wd Xterra Auto.
Thank you!
Thank you!
