Just bought myself a 2000 Xterra SE Auto. The previous owner said he just had the two keys and no keyless entry remote. I'm assuming the SE had this installed standard right? If so, is there anyway to get a replacement?
1. Get inside the vehicle close and LOCK all doors using the lock/unlock switch on the driver's side door. (do not use the remote)
2. Insert your key into the ignition and remove it 6 times within 10 seconds. You will need to fully insert and remove the key during this step each time in roughly one second intervals. The hazard lamps will flash when done correctly. If the hazards do not flash do the procedure 10 times rather than 6.
3. Insert the key in the ignition and turn it to the ACC position.
4. Within 5 seconds push the lock button once on the new remote(your hazards will flash confirming programming.
5. If you have other remotes including new and existing working remotes follow this step, if not skip to step 6. UNLOCK then LOCK the doors by using the lock/unlock switch on the driver's side door. (do not use the remote) Within 5 seconds press the lock button on the remote you are now programming. Your hazard lamps will flash to confirm programming. Repeat this same process for all remaining remotes to be programmed.
6. Once you have programmed all remotes turn the ignition to OFF and completely remove the key from the ignition. UNLOCK all doors using the lock/unlock switch on the driver's side door. (do not use the remote)
I bought a couple of key fobs last week on amazon. They were like $8 each, came with battery, and the above programming sequence worked perfectly. Very easy to do for little cost. The ones I bought were amazon item number B00KTJ8K54.
There are 2 types look on black box under the steering wheel for the code and match with ones you are buying.The code on mine is KBRASTU15 and i dont know the number on the other one but you can not interchange.
I don't seem to have a black box under my steering wheel. I thought all SE models came standard with keyless entry?
75.2K members
