I've Nissan Xterra, Year: 2007
I've some problems. I select all channels of radio frequencies with odd numbers. But I came with the frequencies of even numbers.
For example: I select those channels frequencies: 94.3 - 97.1 - 97.3 - 100.1 - 101.1 - 105.3
But i can't select those: 94.2 - 94.4 - 97.0 - 97.2 - 97.2 - 97.4 - etc...
Somebody can helpe me?
Best regards
Sure, you don't NEED the evens, as no stations use them.
The FM broadcast in the United States starts at 88.0 MHz and ends at 108.0 MHz. The band is divided into 100 channels, each 200 kHz (0.2 MHz) wide. The center frequency is located at 1/2 the bandwidth of the FM Channel, or 100 kHz (0.1 MHz) up from the lower end of the channel.
So, NO US station will have an even decimal point....they will all have to be odd.
If they have even decimal stations, its STILL a situation where the band is split, so, they MIGHT come in if you tune to the 2 nearest odd station selections and try.
There is a part called an "FM Adapter", if you get one locally with even station options, or, an analogue one that you simply tune in manually, that should work. (You plug it into the AM input historically)
Just get a new radio from a local source and call it a day.
I just went to Crutchfield.com and did a search for "European tuning" which produced a list of radios for you. You can always find what you want and buy locally.
75.2K members
