02 Auto SE with security system
Finally got her home to work on and I had to jump the battery off to do so.
Now this morning she won't start with the jump box.......ok, my box is closer to ten years old than not.
Replaced the jump box and tried to jump it with my truck.....no dice.
I'm getting full power to the inside of the cab.
Radio and air kick on full blast (now that I've left a battery tender on it all day),
and I've tightened down the terminals. So bad connection is out. And dead battery is out.
When I'm on the outside of the car, security light stays solid and when unlocked, it goes out. However, when I put the keys in the ignition........nada.
I tried the trick where you lock/unlock doors and ignition. Nothing.
Fuses are all good.
When you turn the key, there is only a small click and just the one. Doesn't even sound like a relay......and certainly not a bad battery.
Only thing I haven't done is hit the starter with a hammer
Maybe it's being immobilized still?
If y'all have any ideas........let me know
Fuses are all good.
