Hello,
Just completed the oil pan replacement on my 2002 X-Terra. Need the torque specs for the following bolts:
- the 4 bolts mounting front differential . The 50ft-lb spec I used seemed too low.
- the 6 bolts on each CV shaft where it bolts to the differential
- the 4 bolts for the front u-joint
- the 3 bolts on PASS frame rail for the steering stabilizer.
