Hit Rut - Huge Bang - Suspension Issues ... - Nissan Xterra Forum: Xterra Forums
Old 02-25-2013, 02:26 PM
cussong cussong is offline
Member: #20391
cussong is on a distinguished road
Hit a rut on the way home --- heard huge bang --- got out of truck and see that rear suspension has shifted back and down ---- rear tires moving but rubbing against mudflaps. I nursed it home but am thinking I should get it towed to the garage. Broken spring? The rut wasnt that big and I wasn't going very fast. Advice
Old 02-25-2013, 02:30 PM
kkolze kkolze is offline
Member: #13302
kkolze is on a distinguished road
Is it one side or both?
get under it and look... check the leaf springs mounts/shock mounts/u-bolts....
if you moved it enough to be rubbing, it should be fairly obivious what is causing it.
Old 02-26-2013, 12:08 AM
slightlywicked76 slightlywicked76 is offline
Member: #36773
slightlywicked76 is on a distinguished road
Post some pics of the carnage and we can tell you what is broken.
"African Family Truckster"
[x] PML
[x] 265/75R-16s
[x] Light bar w/KCs
[x] LoPro Roof Rack (self made)
[x] Front, Engine & Trans Skid Plates (self made)
[x] Bilstein 5100s all the way around
[x] Warn Manual Hubs
[x] Idler Arm Brace
[ ] Transfer Case Skid Plate
[x] Replace Headliner
Life in the Congo is tough, it is tougher with a weak truck!
Old 02-26-2013, 02:56 AM
Fzzt's Avatar
Fzzt Fzzt is offline
Moderator
Member: #3462
2009 OR Xterra
Fzzt has a spectacular aura about themFzzt has a spectacular aura about them
Towed to a garage may be a good idea as your brakes may be compromised.
Traded in all my project cars for a new Xterra, not an ounce of buyers remorse. My build thread
Old 02-26-2013, 12:59 PM
TJTJ's Avatar
TJTJ TJTJ is online now
Sage Mentor/Moderator
Member: #374
TJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to behold
Talking
If the U-bolt clamps broke, etc...there may not be much holding things together, and you can have a quite dramatic accident continuing to drive it. After that, for the suspension to crash, and let the axle shift to the rear, the front leaf mount can break, or, let go if the last leaf (With the loop) breaks, etc.
The accidents you can have are still dramatic though, but slightly less spectacular.
-TJ
TJ's Build Thread ---> http://www.clubxterra.org/forums/showthread.php?t=11532
DIYS http://www.clubxterra.org/forums/showthread.php?t=16434
2001 Xterra SE, 2003 V6, 5 spd, Shrock Sliders, Bumpers and Skids, Warn 9.5xp Winch w/125' MasterPull II, OBA w/4Gal Tank & 4 CFM Compressor, Revolver Shackles, Deaver 3-Pack + Calmini 2-Pack + OEM Leaves, Bilstein 5150, SLR UCA, Diff Drop, 3" SL, 2" BL, 33x13.5/16 LTB's, Snorkel, Electric Fan Swap, etc...
Old 02-26-2013, 06:57 PM
midget28's Avatar
midget28 midget28 is offline
Member: #4620
midget28 will become famous soon enough
More than likely, if the rear tire has shifted, you broke the leaf spring center pin. Cheap fix providing nothing else broke a center pin is roughly $8 depending on where you go.double check your brake lines ,leaf springs, and shocks checking for fresh scratches or breaks.
02 Xterra beaten and battered but still going strong. MAKE IT OR BREAK IT. http://www.miobi.org
3/4ton SAS on 37s.
Build thread http://www.clubxterra.org/forums/sho...ight=midgets+x
