2000 Nissan Xterra Stalling and Jerking - Page 2 - Nissan Xterra Forum: Xterra Forums
Old 01-21-2013, 09:28 AM
estarguars estarguars is offline
Member: #38286
200 Xterra
estarguars is on a distinguished road
I already replaced the maf sensor. It's in the shop, I will update as soon as I hear back. Thanks guys.
Old 01-24-2013, 03:11 PM
Member: #38286
200 Xterra
Mechanic is saying that it may be the ECM computer. Would this make sense?
They are trying to find a used one to test.
Old 01-24-2013, 06:52 PM
Possible, it tells everything when to do anything, based on dozens of sensors. I knock the 1st gens for having a simple computer, but if it can't tell a fuel injector to go, or misreads the incoming air volume, then it will not run right.
Old 02-15-2013, 12:00 PM
Member: #38286
200 Xterra
Took it to a mechanic that specialized in Nissans and he solved the problem! Took about a month but its back to running awesome (knock on wood).
Supposedly it was a corroded wire in the main wire harness that led to the distributor. Strange that it was so simple but I didn't see any past or related issues?
Old 02-15-2013, 12:44 PM
Very strange but glad you got it fixed. At least you know your distributor and MAF are good to go now
Old 02-16-2013, 09:39 AM
kms1990 kms1990 is offline
Member: #34507
now we will know to tell people to look for that as well, glad you got it worked out.
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
Old 02-16-2013, 10:00 AM
devinfox devinfox is offline
Member: #39194
devinfox is on a distinguished road
take off the intake hosing right before the throttle body and look inside. there is a butterfly valve in there. sometimes it may get a carbon and dirt build up and become stuck in one position. id take that off, get a little bit of carb cleaner, a tooth brush and clean that thing out.
you should be able to with one finger just posh it open and closed its got a very light spring holding it in place. try that. its happened on my old 94 4runner. its happened on my girlfriends saturn vue and my father in laws chevy taho.
-devin
Old 02-17-2013, 06:54 AM
bludblu bludblu is offline
Member: #26504
bludblu is on a distinguished road
My 2000 with 165k is doing the same thing. I replaced distributor, wires and plugs. Ran like new for a month, now sputtering under light throttle, losing power. Any ideas?
  #19
Old 02-17-2013, 12:49 PM
TCypress's Avatar
TCypress TCypress is offline
Member: #32392
TCypress is on a distinguished road
You may have a cracked sending unit at the lines I just replaced one of them with the same issues
Sent from AutoGuide.com App
  #20
Old 02-18-2013, 05:04 PM
Member: #26504
I am not the best versed when it comes to working under the hood of the truck. Which sending unit? What lines?
