2000 X bad idle, bad mpg, did everything! - Nissan Xterra Forum: Xterra Forums
Old 02-15-2013, 01:55 AM
sgt_g sgt_g is offline
Member: #33731
sgt_g is on a distinguished road
So I hate doing this but I am at a loss with this. I have searched and searched and done all the recommended stuff but still not change. I am not even remotely new to building and modding cars so the fact that this is stumping me is really pissing me off.
-has just over 100K miles.
-no check engine codes.
-Idle’s like crap will die occasionally at idle.
-Drives and accelerates fine.
-Gets about 120-140 miles per 16 gallons of gas.
-mods are CAI, and muffler
-I have replaced: plugs (ngk), wires(oem nissan), distributer(a1Cardon), fuel pump(bosch), fuel filter(bosch), cleaned MAF, radiator(dayco) and timing belt with all associated bits.
Still idles like crap and still gets poor mpg. Help!!!!! My Audi was easier to fix then this thing is.
Old 02-15-2013, 06:13 AM
jugrnot's Avatar
jugrnot jugrnot is offline
Member: #28211
jugrnot is on a distinguished road
Knock sensor? The knock sensor does not trip the CEl, but can be bad. If bad will retard the timing. Planning on changing mine when the weather gets better. What oils are you running? Also might check into the PVC value.
Old 02-15-2013, 06:37 AM
Member: #33731
5w30 i think. After driving it a little while after changing the pump it got better but is still not right. If the knock sensor is bad im gona do the risistor. Pcv valve is not a bad idea. Ill order that along with the upper manifold gasket. I dont think its the KS though because there is no loss in power semse before it started running like crap
Old 02-15-2013, 09:36 AM
Itsme Itsme is offline
Member: #16990
Itsme will become famous soon enoughItsme will become famous soon enough
Maybe the egr is you issue. Even the vac hose going to it can cause issues.
Keep us informed, as the more info you have for us the better the help we can give.
ps. It is not the knock sensor!
Old 02-15-2013, 10:20 AM
Xterra Mike's Avatar
Xterra Mike Xterra Mike is offline
Silver Submarine
Member: #2784
2001 SE Xterra
Xterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the rough
Try replacing the MAF sensor. I was having the same issue. Just cause you cleaned it doesn't mean its good. Mine looked fine but when i replaced it my truck ran like a champ. If it doesn't fix the issue you can always take it back to the store for a refund.
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
http://www.clubxterra.org/forums/sho...terra+mike%27s
Fan Club:
http://www.facebook.com/group.php?gid=118570174822483
Old 02-15-2013, 05:12 PM
Member: #33731
Maf is not a bad idea. Only issue is im in korea so returning it is not an option. If you unplug it will tge ecu revert back to cold start mode like some cars do?
Old 02-15-2013, 06:34 PM
Not sure what the cold start mode is but if you unplug the MAF and try to start it they will generally not run. If you unplug the MAF while running the truck will die. Unplugging the MAF while running, allowing the truck to die, turning off the key, plugging the MAF back in, and then re-starting the engine will clear all of the stored/learned values in the ECU.
Old 02-16-2013, 04:02 AM
Member: #33731
I ask because on some cars like audi's for example if you unplug the maf the ecu will revert back to cold start mode when it doesnt read the maf at all and runs the motor based on presset readings. Helps a lot to daignose a bad maf. Sounds like the xterra will not work that way.
Old 02-16-2013, 07:38 AM
Silver Submarine
Member: #2784
2001 SE Xterra
no it will not.
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
Fan Club:
Old 02-16-2013, 08:59 AM
kms1990 kms1990 is offline
Member: #34507
i agree on replacing the maf sensor also check if your gettin p0325 or p0328 codes (dont turn on light) and as you said do the bypass if you do, see if that helps, but mine has a p0325 code and i get 15.5-18mpg. also try cleaning your throttle body seafoam makes a throttle body spray that works great for this. you may also try the diy seafoam in the diy section here it may also help, since you have no cel it cant be anything too major.
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
