DT Headers on '03 S/C - DONE - Page 10 - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Nissan Xterra Mods > Performance Mods
Old 05-26-2012, 12:41 PM
Swamp-Man's Avatar
Swamp-Man Swamp-Man is online now
Member: #32983
Swamp-Man is on a distinguished road
I am planning on purchasing the DT headers since my manifolds have the little cracks going on....
I don't have an appropriate space to do work for this installation so I will have to get a muffler shop to do it for me. What sort of hours are we looking at for labor? My X is at stock height so I would like to hear from the other fellow X guys if it really will cause that much of an increase in labor hours.
I appreciate all the great info on this forum!!
2002 Xterra SE - Supercharged - Automatic - 4WD
Hankook Dynapro A/T 265/65/R17
Heavy Duty Bilstein Shocks for 3" lift
Rear Sway Bar removed
Old 05-27-2012, 08:28 AM
phrog man's Avatar
phrog man phrog man is offline
Chrome can go to hell
Member: #4157
phrog man will become famous soon enough
http://www.clubxterra.org/forums/sho...d.php?p=493094
Something I wrote on a similar thread.
Do your research on a good shop because it's going to be a lot of man hours and a complicated job!
2004 BLACK X-AUTO
  #93
Old 05-29-2012, 08:48 PM
justageorgiaguy's Avatar
justageorgiaguy justageorgiaguy is offline
Member: #11398
2003 SE-SC Xterra
justageorgiaguy is on a distinguished road
Sorry for the delayed response. It's hard for me to say if the headers alone are worth it, but I am sure they are. I did the headers and the s/c pulley & nismo cat back at the same time, so the gains were huge. Oh, and there is no MPG gain....i would bet a loss, but the s/c drinks gas either way.
2003 SE S/C 4x4
My Photography:
http://www.edgewatermedia.com
http://www.jdavidsonart.com
Blog: http://edgewatermedia.wordpress.com
  #94
Old 12-31-2012, 11:56 AM
fatkid_UH-60's Avatar
fatkid_UH-60 fatkid_UH-60 is offline
Member: #1182
2004 XE Xterra
fatkid_UH-60 is on a distinguished road
I've just finished with my header install, and yes without the 2" body lift, it was much longer of a job than I anticipated. I had to cut on the drivers side to get the O2 sensor to fit against the body, and drop the front drive shaft to get the old header out. Plus my EGR tube was frozen stuck, and I ended up having to cut the header around it to get it out. ON the passenger side, my aft O2 sensor was so stuck i couldn't get it out before pulling the down pipe. in order to do that, i had to move the transmission cross member, jack up the transmission to hold it up, and then get the cat/down tube out.
K&N CAI, Shrockworks front and rear bumper w/ tire carrier, Shrockworks engine/tranny skid plate, AC 3" Suspension Lift and extended shackles, Baja Rack w/Light Bar, 2 Hella 500s and 4 Hella 700s.
"Many Bothans died to bring us this information"
  #95
Old 12-31-2012, 08:29 PM
NoWhining's Avatar
NoWhining NoWhining is offline
Member: #28139
NoWhining is on a distinguished road
I wish I could run headers in California, but the smog check stations won't pass them (or it's not worth the hassle). What mufflers do you have on that? I really like my flowmaster setup.
When Hell Freezes Over, I'll Ski There Too!!
  #96
Old 02-07-2013, 07:48 PM
nevada68 nevada68 is offline
Member: #14973
nevada68 is on a distinguished road
do you get a benefit from the catback by itself or do you need to do headers as well on the SC models? i have an '04 and was thinking about installing one. from the sounds of it (pun intended) it would not be the nismo lol.
  #97
Old 02-14-2013, 10:46 AM
vinmonty vinmonty is offline
Member: #37679
vinmonty is on a distinguished road
Dude, I had my guy put these in for me. He put the CEL on the front o2 sensors instead of the rear cause he assumed that because the driverside o2 sensor wouldnt fit that the CEL were just extensions. Cut you show me and tell me where and how you CUT to get the o2 sensor in the driver side? I also have no BL. That way, he can get the front o2 sensors in without any CEL and put the CEL on the rear.
My SES light keeps popping on and off and I have a bad lag.
Tags
doug, haders, supercharged, thorley, xterra
