New to the Club - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > General > New Member Introductions
Old 02-01-2013, 03:32 PM
scotty1080's Avatar
scotty1080 scotty1080 is offline
Member: #38839
scotty1080 is on a distinguished road
New to the Club
I have a 2002 Xterra 4x4 SE Charged with a lift. About to give her a makeover any suggestions would be awesome!!
Old 02-01-2013, 03:58 PM
Revu's Avatar
Revu Revu is offline
Member: #27745
Revu will become famous soon enough
Welcome to the club!
That'll make a great project, and there are so many things you can do it'd be impossible to even begin giving some tips and suggestions without knowing what effect you're going for. I'd recommend looking around at what others have done, take note of what you like, and then have fun with all
See you around!
The Project Goes On...
Old 02-01-2013, 05:24 PM
Welcome to CX
Old 02-03-2013, 08:23 AM
Itsme Itsme is offline
Member: #16990
Itsme will become famous soon enoughItsme will become famous soon enough
Hi and welcome to Club X
Old 02-04-2013, 12:20 AM
slightlywicked76 slightlywicked76 is offline
Member: #36773
slightlywicked76 is on a distinguished road
Welcome. The only suggestion that I would have is research the different things that you can do out there and decide what you would like to do. Then plan out what you want to do, this reduces the amount of times you are putting things on and off allows you to get all the necessary parts in before you start a project. Good luck!
"African Family Truckster"
[x] PML
[x] 265/75R-16s
[x] Light bar w/KCs
[x] LoPro Roof Rack (self made)
[x] Front, Engine & Trans Skid Plates (self made)
[x] Bilstein 5100s all the way around
[x] Warn Manual Hubs
[x] Idler Arm Brace
[ ] Transfer Case Skid Plate
[x] Replace Headliner
Life in the Congo is tough, it is tougher with a weak truck!
