Stock vs. 3"SL - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Offroad Modifications 1st gen (00-04) > Offroad Suspension & Steering
Old 01-28-2013, 10:29 AM
kkolze kkolze is offline
Member: #13302
kkolze is on a distinguished road
Stock vs. 3"SL
Because I am bored and have seen people ask....
Stock:
3" Articulator Suspension Package With Bilstein Shocks
Old 01-28-2013, 11:11 AM
That is some flexibility!
Old 01-28-2013, 12:37 PM
Revu's Avatar
Revu Revu is offline
Member: #27745
Revu will become famous soon enough
Definitely cool
Thanks for posting the comparison!
The Project Goes On...
Old 01-28-2013, 04:47 PM
OneGearhead OneGearhead is offline
Member: #34710
OneGearhead is on a distinguished road
NICE! I was wondering how good the articulator package was. Looks like it flexes out pretty good. What size tires are you running with it? It says you can only run 32's with factory backspaced wheels. Is that true or can you run 33's with some minor trimming?
Old 01-28-2013, 07:28 PM
I ran 33x12.50x15 on OEM rims with the articulator lift and a 2" body lift for some time. No cutting required on the rear and only minor plastic trimming required on the front. The rear tire when fully stuffed will either rub on the frame or the inner fender a bit. All I did was to fold over the panel edge of the inner fender to protect the tires from the potentially sharp panel edge.
Currently I'm running 4.75 BS but no pics with that setup but it flexes a bit better now than it did with the OEM rims.
OEM rims and 33's in the pics below and it will go a bit farther now with the 4.75 BS rims.
Old 01-29-2013, 05:05 AM
Member: #34710
[QUOTE=RacerXXL;524136]I ran 33x12.50x15 on OEM rims with the articulator lift and a 2" body lift for some time. No cutting required on the rear and only minor plastic trimming required on the front. The rear tire when fully stuffed will either rub on the frame or the inner fender a bit. All I did was to fold over the panel edge of the inner fender to protect the tires from the potentially sharp panel edge.
QUOTE]
Good deal!
BTW Racer: your X is awesome!
Old 01-29-2013, 02:28 PM
M3C.CA's Avatar
M3C.CA M3C.CA is offline
Member: #27059
M3C.CA will become famous soon enough
I'll play. Mine's a bit different...
SOA + stock shackles + Eagle stock replacement (no lift) leaf packs:
Full droop:
Rear up-travel will be better after I modify the bumpstops. Right now because there's an additional ~2" of spring perch, leaf pack and spring plate on top of the axle tubes that hits the bumpstops before the tubes would if it was still spring-under. She still stuffs pretty good though...
GRANITE 2003 SE SC
BUILD THREAD
wonton SAS in the works.
