Clicking sound when A/C is on - Nissan Xterra Forum: Xterra Forums
Old 10-05-2012, 09:28 AM
stevencox93's Avatar
stevencox93 stevencox93 is offline
Member: #26536
stevencox93 is on a distinguished road
So My car seems to make a clicking sound anytime the air is on, mostly when the A/C is on but I have heard it when the heat was on once. Why is this? Any tips would be appreciated.
Sent from my iPhone using AG Free
[x] 16x8 XD Series Hoss Wheels
[x] 265/70 Falken Wildpeak A/T
[x] Bedlined Plastics
[x] Tinted Tails and Markers
[x] Soon to be MONSTALINED
[x] Bilstein Shocks
[x] Bedlined Headliner
[ ] 3" Sl
[ ] 2" Bl
[ ] 18 XD Series Rockstars
[ ] 33" Trail Grapplers
[ ] HD Steering
Old 10-05-2012, 10:19 AM
xtacular xtacular is offline
Where is it coming from? Below the glove box?
Old 10-05-2012, 10:33 AM
intender intender is online now
if its below the glove box it could be something has gotten into the blower box. I somehow ended up with some of my sons goldfish in my box. made a horrible noise until I pulled the stuff out.
if your talking about a clicking sound from the engine bay its the compressor clutch engaging and disengaging. in a good working system it shouldnt happen too often, if your system has a leak or other problem with it (like mine) it will click on and off every 10 or 20 seconds. and if its from the engine bay, and your hearing it when the heat is on, you most likely have it on defrost. anytime you turn it to defrost the ac runs to pull the moisture out of the air.
Old 10-05-2012, 02:32 PM
Member: #26536
It's from the engine bay and it's like a clicking you can hear when the car over anything when the car is running and whenever I turn off the car I sometimes get a "aahhhaahhh" sound like after someone gets done drinking a cold drink if that makes sense?
[x] Bilstein Shocks
[ ] 3" Sl
[ ] 2" Bl
[ ] HD Steering
Old 01-15-2013, 07:12 PM
arksecfan's Avatar
arksecfan arksecfan is offline
Member: #38221
arksecfan is on a distinguished road
Mine has been making that same sound. I has really wanting it not to be the compressor. So I take it that it is best to just replace the compressor or is there something else that can be done.
Far better is it to dare mighty things, to win glorious triumphs, even though checkered by by failure... than to rank with those poor spirts who neither enjoy nor suffer much, because they live in a gray twilight that knows not victory nor defeat.
Theodore Roosevelt
"Bandit" build thread.
http://www.clubxterra.org/forums/sho...203#post522203
Old 01-16-2013, 03:17 AM
Itsme Itsme is offline
Member: #16990
Itsme will become famous soon enoughItsme will become famous soon enough
It should be clicking on and off, so don't let that cause you any grief! It is working as it should!
It is a pressure driven compressor and whenit is working well, it will cycle often.
When they don't cycle at all, is the time to worry!
Old 01-16-2013, 12:37 PM
irishprodigy's Avatar
irishprodigy irishprodigy is offline
Member: #35130
irishprodigy is on a distinguished road
Hey, it always could be like mine and 2 won't blow! But I live in Florida and drive 99.999% of the time with the windows down and it doesnt bother me
I'm Adam!
04 XTerra - The WARSHIP!
Mods:
[X] PML
[X] 2" BL
[X] 285/75x16 BFG AT KO
[ ] Bedline bedline bedline!!!
[ ] Custom front winch bumper
[ ] Rear tire swing bumper
[ ] Sliders
[ ] Snorkel
[ ] SAS with rear SUA
[X] Get dirty!
Old 01-16-2013, 10:01 PM
arksecfan's Avatar
Member: #38221
This is not a little rattle!!!! This sounds like a rod is about to come out the side of the block but only when the A/C or Defrost is on. The heat and vent work just fine and I know that it is not the blower I took that apart and checked. I am not sure 100% sure what the sound is but it is under the hood drivers side and it makes a lot of noise!!! When I turn the A/C off you can hear the sound slow down and then stop. I am not sure may need to let a pro look at it.
Theodore Roosevelt
Old 01-16-2013, 10:02 PM
arksecfan's Avatar
Member: #38221
Oh and all of the dial settings work just fine. Just rattles like crazy when on.
Theodore Roosevelt
Old 03-17-2013, 03:32 PM
mlowe mlowe is offline
Member: #40306
mlowe is on a distinguished road
I'm not a mechanic but my father was and as a kid, from middle school through college, I had to work in the shop on weekends, summers and hollidays. From what I've read, and the noise you describe is loud but stops when you turn the AC off, I think the clutch could be going out.
