New guy to the club here. I need help. - Nissan Xterra Forum
post #1 of 7 Old 01-14-2013, 05:22 AM Thread Starter
Fallenblade4
Fallenblade4 is on a distinguished road
Hello everyone. I'm new to the club and would like to get working on my
2004 xterra
Color- Canteen Green
Everything is stock and would love to have a DIY 2" BL
And put Red shackles on and front and rear bumpers on.
But since I'm like most guys money tight but not that tight.
If anyone can help me out on where to buy and price.
Let alone if anyone has done these things to there X can tell me the easiest way to do it. I'm a Nissan man and I love the site and what everyone has done to their X's. Thanks again!
Fallenblade4 is offline
post #2 of 7 Old 01-14-2013, 05:46 AM
Ricel
Ricel's Avatar
Ricel has a spectacular aura about them Ricel has a spectacular aura about them
Welcome up.
Most people start by doing the PML (or poor mans lift). This is actually a simple lift using aftermarket shackles for the rear leafs and can be found at 4x4parts.com
Then after you raised the rear with the shackles you have to tighten your torsion bars in the front. The more pressure you apply to them, the more they can raise up the front.
Check you the DIY section to get a feel for how to do a PML.
Then from there, get your feet wet with some wheeling. I've purchased things as I've progressed as a wheeler. So when my truck starts to get limited on specific areas of the trail, I'll look to upgrade that, instead of throwing everything at it at once and not know how the truck handles yet.
-Curt
2002 Black Xterra SE 4x4
:Lets just say its getting to be an expensive mod list:
Originally Posted by J Everett View Post
I'd rather attempt to put together a 5000 piece puzzle of nothing but blackness than set the pinion lash on a Dana diff.
Ricel is offline
post #3 of 7 Old 01-14-2013, 06:09 AM Thread Starter
Fallenblade4
Thank you for the info
Thank you for the info ill look into it and go from there.
What do you think would be my best starting point? Pml or shackles? I love the way the 2"BL looks. By the way this is my DD.
post #4 of 7 Old 01-14-2013, 06:30 AM
robcarync
Quoted: 83 Post(s)
robcarync has a spectacular aura about them robcarync has a spectacular aura about them robcarync has a spectacular aura about them
Hey, read the PML How to (link in my signature)
The PML IS shackles. Buy 70 dolalr shackles:
https://www.4x4parts.com/nissan/xter...les-p-145.html
That raises the rear.
The front suspension uses torsion bars as a spring. This stock suspension in the front is adjustable to an extent. By adjusting the torsion bars, you can lift the front a little to match the shackles.
Also, just as a matter of semantics, you aren't exactly increasing the pressure of the torsion bars. The torsion bar springs hold the same weight regardless of ride height...thus they twist the same angle as before. You are just rotating the orientation of the entire bar if that makes sense. Point being, you will not wear your torsion bars out any faster by raising them.
and...WELCOME!
33x10.50R15 BFG KM2 | Lokked and Dropped Front Diff | Lift Shackles | 3" UCA's | 3" Bils | 2" BL | TC IAB | Bandit 4x4 Idler Arm Bushings | Grassroots CL | Custom Bumpers and Tire Carrier | Shrock Sliders | RSB Delete | Cobra 19 DX III CB | 4' Firefly
How To: < Remove Rear Sway Bar > < PML > < Re-Index Torsion Bars > < Lokk and Drop >
robcarync is offline
post #5 of 7 Old 01-14-2013, 08:46 AM
Itsme will become famous soon enough Itsme will become famous soon enough
Hi and welcome to Club X
The PML includes the shackle install.
Itsme is offline
post #6 of 7 Old 01-14-2013, 11:54 AM
Ricel
Ricel's Avatar
Hey thanks rob for clarifying, just didn't explain it correctly!
I'd hold off on the body lift for now. Wait until you increase your tire size. A BL without larger tires makes them look tiny. Haha
-Curt
Ricel is offline
post #7 of 7 Old 01-14-2013, 01:29 PM
robcarync
Quoted: 83 Post(s)
No problem man...I've seen a few new guys get confused, thinking they are actually twisting their torsion bars tighter and afraid they will twist them too tight. Just wanted to clarify, the torsion bars aren't getting twisted any tighter
