Oil Pan replacement - Page 3 - Nissan Xterra Forum: Xterra Forums
Old 10-30-2012, 08:49 PM
legend869's Avatar
legend869 legend869 is offline
Member: #17515
legend869 is on a distinguished road
Ya I know but a one piece is better
Old 12-30-2012, 09:59 PM
MelkorTDL MelkorTDL is offline
Member: #38242
MelkorTDL is on a distinguished road
Just pulled this off w/o raising the engine
I just did a complete DIY replacement of the oil pan, oil/water pump, timing/serpentine belts, etc... without removing or raising the engine using your thread suggestions. I have pics to help if anyone wants to see. I understand why the labor at a shop is quoted as soooo much. It took 3 weekends, but was welll worth it.
  #23
Old 12-31-2012, 04:11 PM
outwiththeold's Avatar
outwiththeold outwiththeold is offline
Member: #4028
00 Xe 4x4 Xterra
outwiththeold is on a distinguished road
Ok, post them,please.
warn manual hubs,PML, and a ditched rear sway bar.K&N Drop w/ resonators removed.Plastics Repainted Black.
  #24
Old 01-01-2013, 11:28 AM
NaplesXterra2K NaplesXterra2K is offline
Member: #38185
NaplesXterra2K is on a distinguished road
I just replaced the oil pan in my 2000 Xterra and did not have to take the front end out. It is just a little tricky to pull the front end of the drain pan out. It is a 3.5 hour job. Take your time and it will come out ok. When placing the oil pan back, it is a good idea to get the master cylinder in the up position.
  #25
Old 01-06-2013, 06:40 PM
rudytj rudytj is offline
Member: #37984
rudytj is on a distinguished road
master cylinder in the up position....huh?
  #26
Old 01-07-2013, 10:03 AM
Member: #4028
00 Xe 4x4 Xterra
  #27
Old 01-07-2013, 07:33 PM
Member: #37984
what did he mean by "it is a good idea to get the master cylinder in the up position."
  #28
Old 01-07-2013, 09:17 PM
Probably meant Cyl 1 at TDC
  #29
Old 01-07-2013, 11:48 PM
Cavalznti Cavalznti is offline
Member: #37727
2012 Xterra
Cavalznti is on a distinguished road
Originally Posted by bruce372 View Post
just wanted to bump this thread- ive got a 2004 and the oil pan is rusted out and leaking oil.
how hard a job is it to swap out the oil pan.....it looks like its difficult to get access to with all the steering parts in the way.
my local shop is saying 3.5 hours needed to do the job- i assume its a trivial job to remove 1 part, made complex by having to remove half the front end to do the job!!!!
thanks, Bruce
why dont you look up for the site named olx.com i think you will get these oil pans there of second hand at very good price ranges.......
  #30
Old 01-15-2013, 05:16 PM
Member: #38185
What I meant by master cylinder is that once you undo all the bolts, that at the front of the oil pan the bottom of the arm of the front piston may keep you from getting the oil pan out. If you do a quick turn of the ignition key, NOT TO TURN IT OVER but to turn the piston a little, it will move up allowing you to get the oil pan out easier.
