OEM Fog Light install - Nissan Xterra Forum: Xterra Forums
Old 01-01-2013, 09:57 AM
Ryandrew's Avatar
Ryandrew Ryandrew is online now
Member: #37902
Ryandrew is on a distinguished road
I am installing an OEM fog light kit on my 2004 X that was not originally wired for fog lights. I have the hardware (lights) installed, switch wires ran through the firewall on the drivers side, both negatives grounded, everything else ready to connect, but I am trying to figure out where to connect the power wire for the switch.
I want it to turn off when the key is off or out. In other word only be able to come on when the car is on. Click image for larger version
Happy New Years!
Any help is appreciated!
2004 Silver XE V-6 4x2
Inside: Pioneer 3-way door speakers, Aux input above factory unit, Kicker 12" sub, Kicker 250 amp
Outside:PML, 2" BL, Calmini IAB, rear Bilstein 5100's, 265/75/16 Falken Rocky Mountain A/T tires, Bedlinered plastics, Plastidipped emblems, OEM add on fog lights, Cherry Bomb glasspacks
Under the Hood: Stock air intake mod w/ K&N drop in, Amsoil oil and filter, and differential fluid, new timing belt, water pump, thermostat, radiator, belts and hoses.
Old 01-01-2013, 02:48 PM
Ryandrew's Avatar
Member: #37902
I ended up using a fuse adapter, and hooked up a wire to an open slot in the fuse block that only had power when the ignition is turned. Works great!
