gear basket - Page 2 - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Trail Talk > Trail Gear
Old 11-07-2011, 08:48 AM
fishguy fishguy is offline
Member: #14429
2004XE 4X4 Xterra
fishguy is on a distinguished road
I measured it out and am going with the Load Warrior for the same reason you did. I think it will be big enough for what I need and it will look great since it will match the rail width. I think the Mega Warrior would be more than I need and would look odd, to boot!
Thanks,
Evan
Originally Posted by Roadwarrior View Post
I have the loadwarrior, I like how it matches the roof rails in width.
I use it for excess snowboard stuff, camping, spare tire.. I love it
Old 12-04-2011, 10:48 AM
Member: #14429
2004XE 4X4 Xterra
I decided on the Loadwarrior. Just got it and new BFG AT KOs. Will post pics soon. Good timing, too, because the first winter storm hit NM- mountains are going to be fun.
Old 07-06-2012, 01:34 AM
LaserDave LaserDave is offline
Member: #34574
LaserDave is on a distinguished road
Mounting Brackets
I have a 2005 X. I'm debating between the Curt cargo rack and the LoadWarrior. Do the stock Yakima mounting brackets work on the factory cross bars? Or do I need to get another mount (eg Mighty Mounts)? - Thanks
Old 07-06-2012, 09:40 AM
xearth's Avatar
xearth xearth is offline
Member: #13970
xearth is on a distinguished road
the yakima ones that came with the load warrior worked just fine with my cross bars
XEARTH's Build Thread
Old 12-25-2012, 04:55 PM
dmac's Avatar
dmac dmac is offline
Member: #33024
dmac is on a distinguished road
I had a load warrier and it worked ok. What I didn't like is that it sits so high on top of the roof rails. There are a couple of inches from the base to the roof that you can't use. Also the locking brackets are crap. Someone just cut them off with probably bolt cutters and the rack, high lift mount and shovel mount were gone in minutes.. Considering the cost of all these items I took the insurance money and got a Baja rack. It's custom made for the Xterra
and similar to the Gobi at several hundred dollers less.
Old 12-26-2012, 09:04 AM
porsche4786's Avatar
porsche4786 porsche4786 is online now
Member: #25294
porsche4786 is on a distinguished road
I would have recommended throwing out the bolts that come with the rack, and upgrading the hardware to something much tougher and bigger. I've only used mine for camping, so I wasn't worried about it getting stolen. But if I ever use it on a road trip I'll get some larger bolts that are grade 8. And of course, a cable lock as well.
But yes, the baja rack is better!
2004, XE, 5 speed manual
My Build Progress...
