Valve cover gasket replacement - Nissan Xterra Forum: Xterra Forums
Old 06-23-2011, 10:32 PM
Nickolae's Avatar
Nickolae Nickolae is offline
Member: #13822
Nickolae is on a distinguished road
Exclamation Valve cover gasket replacement
Ok ladies and gents. I need to replace both of my valve cover gaskets. The rock auto box came in so it's go time. It seems like a straight forward but time consuming job. Anything I need need to know to keep the surprises to a minimum?
I will post pics.
04 Xterra XE. Goodyear Silent Armor Tires. Volant CAI. PML with Calmini Shackles. Uniden CB Radio. Firestik 2 Antenna. Mud flap delete.
NXM 2011 Video
Old 06-23-2011, 10:36 PM
You are aware that in order to remove the drivers side you will need to pull the intake plenum?
Old 06-23-2011, 11:00 PM
Nickolae's Avatar
Member: #13822
Yes. Is it any more complicated than; unscrew, take off, put back on in reverse order?
NXM 2011 Video
Old 06-24-2011, 07:18 AM
Itsme Itsme is offline
Member: #16990
Itsme will become famous soon enoughItsme will become famous soon enough
Yeah, it needs a new gasket too!
Also while you are under there, check that the waterline hoses are not brittle or leaking. (on the bottom of the plenum)
Old 06-24-2011, 07:40 AM
TimRich's Avatar
TimRich TimRich is offline
Spaz
Member: #2811
TimRich has a spectacular aura about themTimRich has a spectacular aura about themTimRich has a spectacular aura about them
Nickolae, did you try tighting the screws on the valve cover? I thought mine were leaking too then I read somewhere that the scres that hold them on tend to come loose and cause leaking. I tightened mine down and no more leaking. I was suprised how loose the screws were when I tightened them up.
Tim... 2000 Xterra SE 4x4
Mods: K&N Air Filter, AC PML, 17" Pro Comp Wheels, 33" Wild Country MTX, Custom Rear Bumper w/Tire Carrier, 2 inch BL, Hella 500FF's, AC Prerunner bumper, Xoskel light bar with 4 KC Daylighters, AC's IAB, Rancho RS5000 Shocks.
Official Build Thread
Old 06-24-2011, 05:00 PM
Nickolae's Avatar
Member: #13822
Thanks Tim for mentioning the obvious. They were seriously loose. Saved me a ton of work so I got a chance to replace the horn I ruined at NXM and change the oil.
Sorry for the false alarm!
NXM 2011 Video
Old 06-25-2011, 10:44 AM
emmdock emmdock is offline
Member: #8630
emmdock is on a distinguished road
The hardest part for me was the two short coolant hoses behind the intake plenum (near the firewall). Ended up cutting them off and replacing them. Should have started with that idea and would have saved an hour.
2002 Xterra XE 3.3 4x4 auto | JL 500/1v2 + 10W7 | Viper 5901 remote starter | Rear sway bar delete | Bilsteins all around | IAB | 2" DIY BL | KC HiLiTES on homemade roof bar | AC Shackles/PML | 33x12.5/15 Goodyear Wrangler MT/R with Kevlar on Cragar Soft 8s | Skid Row skids | Yakima Loadwarrior | Beginning of a build thread
Old 07-06-2011, 01:49 AM
Danny289's Avatar
Danny289 Danny289 is offline
Member: #27225
Danny289 is on a distinguished road
Same here! exactly my story 13 of 14 absulate loose!
Old 07-06-2011, 07:04 AM
PhilKratz's Avatar
PhilKratz PhilKratz is offline
Location: N.E. Philadelphia Pa. Orig. from Lewes Delaware
Member: #24312
2000 x Xterra
PhilKratz is on a distinguished road
same here man mine were loose not even hand tight! this should be stickied so more people check
theirs.
Sent from my iPhone
Old 12-25-2012, 12:18 AM
kms1990 kms1990 is offline
Member: #34507
almost all mine on passenger side were loose i can tell my valve cover gaskets have been replaced (at least the passenger side) because one of the screws on it was a bolt so they must have lost one screw while doing it.(hopefully they did drivers side and intake gaskets) but they were all loose except that bolt lol. and the ones i could get to on drivers side were all a little loose but i think the intake plenum keeps those tight. i have a small oil leak from what appears to be where the oil pan sits near the rear main seal/bell housing area and my mechanic diagnosed it as a rm seal leak but seeing as those screws were loose and i see a small amount of oil around rear of passenger side valve cover im leaning towards those screws being loose. we will see! wish me the best on it
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
