03 with Rockford Fosgate system head unit replacement - weird sounds - Page 2 - Nissan Xterra Forum: Xterra Forums
Old 01-03-2012, 08:44 AM
idratherberidin's Avatar
idratherberidin idratherberidin is offline
Member: #29812
2003 se/sc Xterra
idratherberidin will become famous soon enough
Very good! Is your X a SC? Even with GLI on mine I could still hear the supercharger through my speakers. Glad you got it fixed and didn't have to do what I did!
Old 01-23-2012, 12:50 AM
LuvMyDux's Avatar
LuvMyDux LuvMyDux is offline
Member: #27848
LuvMyDux is on a distinguished road
I also have the Rockford system and tried installing a new DVD head unit today. I'm also having terrible hissing and interference noises coming through my speakers. In addition, I am hearing this fan like sound coming from under my X, have no idea what's going on? I connected and matched everything correctly on the harness to the deck. How do you connect this Ground Loop Isolator thing? I uninstalled everything and put back the factory deck cuz the noise was so bad.
Old 12-03-2012, 07:19 AM
Delirious Delirious is offline
Member: #37564
Delirious is on a distinguished road
Originally Posted by rjr162 View Post
If its popping when the system first turns on, and also maybe when it turns off (but not in between) then its most likely a timing issue. You can get turn on delay modules online for under $20, and what they do is delay the amp turning on a bit so the audio signal is already on. The pop usually happens when the amp is already on and *then* the audio feed kicks on
Sent from my GT-I9000 using AutoGuide App
1kohm resitor on the amp turn on wire USUALLY fixes "turn on pop" on factory amps
Old 12-05-2012, 12:07 PM
rjr162's Avatar
rjr162 rjr162 is online now
Member: #8871
rjr162 will become famous soon enoughrjr162 will become famous soon enough
Absolutely can help, and is pretty much required on certain Fords (such as the JBL equipped Explorers)
Old 01-02-2013, 06:04 AM
Member: #37564
also finds most nissans dont ground through the harness and gets their grounds in the ISO mounting brackets. most installed head units are only being grounded through the antenna (specially when using a plastic dash mounting kit)...not a good ground. run the HU`s ground dirrectly to a metal brace inside the dash cavity and usually all those popping, pulsing, altinator wine, etc noises will go away.
