How to remove seized engine block coolant drain plug - Nissan Xterra Forum: Xterra Forums
Old 11-28-2012, 04:58 PM
gogogsr gogogsr is offline
Member: #29030
gogogsr is on a distinguished road
Hey guys, i'm flushing my coolant and i'm having a real hard time removing the engine block coolant drain plugs. I was wondering if it is safe to heat the block around the drain bolts?? I tought you were not suppose to heat the engine block to remove bolts, but maybe I misunderstood, lol. These two bolts are a real PITA. Thanks guys
Old 11-28-2012, 05:11 PM
intender intender is online now
I never could get mine to break loose. I tried a torch, and crc freeze off and it didnt budge one bit. Im not sure why you shouldnt heat the engine block, since it gets extremely hot when operating. I wouldnt go from sub zero temps to a hot torch, but normal temps should be fine.
Old 11-28-2012, 05:15 PM
Member: #29030
thanks intender, is there an alternative to removing these plugs? What did you do?
Old 11-28-2012, 10:36 PM
phrog man's Avatar
phrog man phrog man is offline
Chrome can go to hell
Member: #4157
phrog man will become famous soon enough
Can't remember how much room is there bit I would use a 12 point socket attached to a breaker bar then use a cheater bar to increase the amount of torque you can apply. If there is room this always works.
2004 BLACK X-AUTO
Old 11-29-2012, 04:35 AM
Member: #29030
I allready tried that but i dont want to snap the head
Old 11-29-2012, 09:42 AM
Maybe a little 'percussive therapy' around it? It's not really seized, just held in really well by the sealant.
Old 11-29-2012, 09:45 AM
Member: #29030
I will try with impact at like 80 psi
Old 11-29-2012, 11:06 AM
The cooling system holds slightly less than 3 gallons total. The radiator if you have a non supercharged engine holds a little less than half of that. I drained the radiator twice. I made my own 50/50 mix from distilled water and antifreeze and used that to fill it after each drain, and added the system flush additive into the first flush. I followed whatever the directions for the flush was for the the first drain. I let the engine run for about 20 minutes before I drained it the second time to let it mix good. after the second drain I filled it with 50/50 again. I drove it for about 2 weeks and then did another drain and filled again. Probably didnt need the 3rd drain but it didnt hurt. I had just changed the thermostat on my infiniti and forgot I had some nissan antifreeze laying around in the basement and bought more to do the xterra. My wife wanted me to get rid of the antifreeze before our 2 year old got into it (he thought it was bubbles) so it seemed like the best use for it. Either way I drained more out of the system than it holds, although I am sure a small amount of the original coolant is still in the system it should be a tiny amount.
all of that was in vain either way, my upper radiator connector snapped off my radiator a few months later after doing my body lift and I had to fill the system again anyway. I got it connected enough to hold long enough to get home, but used water from a gas station to fill it and had to do it all again to get the crappy water out. Some people dont seem to mind using city or well water for flushing and filling the cooling system, but I never liked the idea.
Old 11-29-2012, 09:27 PM
outwiththeold's Avatar
outwiththeold outwiththeold is offline
Member: #4028
00 Xe 4x4 Xterra
outwiththeold is on a distinguished road
Got mine out with a set of bolt-out sockets.
warn manual hubs,PML, and a ditched rear sway bar.K&N Drop w/ resonators removed.Plastics Repainted Black.
