P300B engine code... - Nissan Xterra Forum: Xterra Forums
Old 11-20-2012, 08:42 AM
Drucifer's Avatar
Drucifer Drucifer is offline
Member: #30607
Drucifer is on a distinguished road
OK. Im running my 2002 with 128k miles on it. I recently lost the timing belt and luckily, got it all bacy together with no internal damage. I was throwing a couple codes (knock sensor, gross evap leak) and resolved them. The knock sensor was handled with a relocation mod and the evap leak was in the canister.
At the same time, I began to get the P300B code for multiple random misfire. Searching the forum here, I found out that the distributor has a bearing issue. So, I replaced that. Timing was set according to instructions with the throttle body sensor unplugged then reconnected. Timing seems to be good. Plug wires were recently (within 1000) miles changed. Plugs were done about 5-6000 miles ago.
On a cold start, I am getting performance issues (i.e. misfiring thats really noticable) until the engine is fully warmed up for about 10 minutes. At 2k on the tach, is where I really seem to notice it. The sound of the RPMs goes up, but the tach starts to drop off. Like I said, this only happens for the first ten or so minutes, then she runs like a top...
Is there any advice out there? Is there a crank re-learn that should have been done after the timing belt? Im getting really frustrated and need some help without having to go to the stealership and donate a kidney to pay for it. Thanks!
Tactical Armor Group Wincher front bumper, KC Daylighters, intake mod, PML with sway away torsion bars, running board delete.
Gotta do the headliner, delete the mud flaps and bedliner the hood, wheels and rocker panels....
Old 11-20-2012, 01:33 PM
I cant seem to find code P300B in the FSM. Are you sure the code is correct? Normally a proper misfire code will direct you to the cylinder in question but the code you are giving does not show up.
You can do the following to erase stored values in the ECM.
Start engine and bring it up to operating temperature
With he engine running disconnect the MAF sensor plug allowing the engine to run until it dies
Shut off the ignition and re-connect the MAF
Start the engine and allow it to idle for 10 minutes
After that drive as you normally would
Past that start pulling spark plugs and look for problems/incorrect gap. Also check to insure the firing order is correct ie the plugs are going from the correct spot on the engine to the correct spark plugs.
Old 11-20-2012, 07:22 PM
cbxterra cbxterra is offline
Member: #18847
cbxterra is on a distinguished road
maybe you mean P0300. I;ve been trying to figure out the same for awhile. going to try that MAF unplug tomorrow. try looking at the sticky for the factory service manuals in the repair section, they have a list to follow to solve the variuos codes
Old 11-20-2012, 08:45 PM
ShiftingSkys ShiftingSkys is online now
In this situation I honestly think that the knock sensor was not bad this time and Was actually trying to tell you you had a problem... Rare I know.
Check all wiring and connectors that lead to the cylinders is what Id say first but you got that covered. Spark Plugs and wires. Now you said you did those so Check
I would suggest distributor cap and rotor second but I believe since you replaced the WHOLE distributor then those should be NEW right? so Check.
The next step is the VALVES or an intake leak. Check to see if the camshaft sensors doing what its supposed to and reading right or a vacuum line is unhooked.
If that is correct I would bet my bottom dollar on the O2 sensors. I would move onto 02 sensors WHY?! Because they are directly in control of Open/Closed Loop on vehicles and with what you stated in CLOSED loop the vehicle runs good. But for some reason in open loop runs like shit. Maybe you damaged an O2 or it got wet or oil fouled.
The last Thing I would say is check to see if the catalytic converter has gone bad so smell the exhaust and see if it smells like rotten eggs in the exhaust.
In rare cases I am sure faulty fuel injectors or computer(which controls the injectors) could be bad with this code in rare cases.
GL But id bet my bottom dollar on O2 simply because you said after 10 minutes the ride smoothes out.
Old 11-23-2012, 03:21 AM
Drucifer's Avatar
Member: #30607
I'm leaning toward a plugged / collapsed catalytic at this point... Lots of noise (exhaust) underbrush driver floorboard, NO power under load...
Back to the mechanic on Tuesday.
Old 11-25-2012, 02:06 PM
Drucifer's Avatar
Member: #30607
If a fellow was to punch out the catalytic innards, (theoreticly, of course) would it throw a code? NY is a catalytic mandatory state and I would never think about breaking the law, but just wondering if it would show up on the scan for the inspection.
Worst case, I guess I'll have to replace the catalytic, but I'm hoping I can resolve this on the cheap...
