Valve Cover Bolts - Nissan Xterra Forum: Xterra Forums
Old 11-10-2012, 02:36 PM
Skull_Stalker Skull_Stalker is offline
Member: #22370
Skull_Stalker is on a distinguished road
Valve Cover Bolts
Does anybody know what size tap I need for the valve cover bolts holes? I changed out the valve cover seals on the passenger side and I either got some RTV in the threads or stripped them and now I hve 2 screws that do not want to go in.
It's a 2001 Xterra 3.3l I believe
Old 11-10-2012, 02:52 PM
I don't know for certain but my guess is going to be M6x1.
Old 11-10-2012, 08:22 PM
Yep, M6x1.0 and the bolts themselves are 25mm.
Old 11-11-2012, 08:44 PM
Scottybones Scottybones is offline
Member: #15154
Scottybones is on a distinguished road
Did you have to change out the seals because of leaking? My wife's just started leaking on the passenger side and I'm trying to figure out if I can just change the gasket or if there is something else wrong.
Old 11-12-2012, 11:09 AM
Cyclemut's Avatar
Cyclemut Cyclemut is offline
Most Halal Mod
Member: #2547
02 Xterra
Cyclemut has a spectacular aura about themCyclemut has a spectacular aura about themCyclemut has a spectacular aura about them
Probably just the gaskets are old and hard. Easy to replace and is fairly common as a leak generator.
Nissan Sport Magazine
The world's only Nissan specific mag!
Old 11-12-2012, 11:37 AM
miskywhisky miskywhisky is offline
Member: #9010
miskywhisky will become famous soon enoughmiskywhisky will become famous soon enough
Also just try hand tightening them first as they are known to come loose. Don't put your shoulder into it or anything cause its just aluminum.
